Ignition 8.0 perspective had a checkbox to filter bad quality data on tag history bindings
https://docs.inductiveautomation.com/display/DOC80/Tag+History+Bindings+in+Perspective
Ignition 8.1 does not have this checkbox on its tag history bindings.
How do I filter out bad quality data on this kind of binding now?
Is there an undocumented property I can use for Dynamic Tag paths (bottom of document) to implement this functionality?
The application where I’m trying to do this is using a dynamic tag path to change the tag bindings based on properties passed into the view so I’d be perfectly happy to add a property to the key array to implement this functionality if there is a property I can use for that.
system.tag.queryTagHistory also has it’s parameter to filter bad quality data removed so I guess I can’t even do a script transform to pull in the data.
I have a call in with support but I thought maybe someone knows the answer to this to save me some time.
Update:
Support confirmed this feature was inadvertently patched out and it will come back in a coming release.
