How do I find out where my gateway is and what port FactoryPMI is running on?
If you click on Help->About FactoryPMI in either the runtime or designer, you’ll get a helpful debugging window.
Here’s my About FactoryPMI window:
Version: 2.0.0_05 (build 950)
FPMI Gateway Location: 192.168.1.36:80
Other Cluster Nodes
192.168.1.115:80
Java Version: Sun Microsystems Inc. 1.5.0_10
JVM Memory (used/max MB): 56.97/508.06
The Gateway launch page provides even more info.
Determining the port is tricky if you’re not running the software. Rather than mess with a port scanner, you’ll want to run the Monitor FPMI Gateway utility that is installed locally on every FactoryPMI Gateway by default. It will communicate directly with the Windows service and provide a great deal of information.
