How do i get my server out of redundant mode?
I have a server. It was originally a backup server. Now, I need to make independent. So I set the primary server to be Independent. Then over on the backup I restart it. I set the value to independent in the redundancy.xml nothing works!!
It looks like you’re using a license that is only valid for a backup gateway.
That is a real pain… I need to delete a module off of it. Because I can’t get them to synch. The trial version of modules I cannot uninstall. Is there another way besides the gateway webpage?
Delete the module file from $IGNITION/user-lib/modules and restart the gateway.
