How do i import CSV file into Table
Hello, i have tried to import a CSV file into the table but i have experienced ValueError.
This is the script on the button:
filepath= system.file.openFile(“csv”)
string= system.file.readFileAsString(filepath)
data = system.dataset.fromCSV(string)
even.source.parent.getComponent(‘Table’).data = data
This is the data i would like to import into the table
on the last line, the T in event is missing and ` (grave accent) instead of ’ (single quote)
filepath = system.file.openFile(“csv”)
string = system.file.readFileAsString(filepath)
event.source.parent.getComponent(‘Table’).data = data
The system.dataset.fromCSV has to be in a special format and not from an excel save as CSV.
if you want to use the excel CSV format the link below page has an alternative script.
https://docs.inductiveautomation.com/display/DOC79/Exporting+and+Importing+a+CSV
Weird, I copied the code I posed from ignition to the website, then i copied it from the website back into ignition and it screws up the single quote and double quotes.
This worked for me.
# Import Python's built-in csv library.
import csv
# Ask the user to find the CSV in the local file system.
path = system. file .openFile( "csv" )
# Create a reader object that will iterate over the lines of a CSV.
# We're using Python's built-in open() function to open the file.
csvData = csv.reader( open (path))
# Create a List of strings to use as a header for the dataset. Note that the number
# of headers must match the number of columns in the CSV, otherwise an error will occur.
# The simplest approach would be to use next() to read the first line in the file, and
# store that at the header.
header = csvData. next ()
# Create a dataset with the header and the rest of our CSV.
dataset = system.dataset.toDataSet(header , list (csvData))
# Store it into the table.
event.source.parent.getComponent( 'Power Table' ).data = dataset
Yeah, you need to put code in a code formatting block. Basically, three backquotes by themselves on a line above and again on a line below your code. Like so:
pasted code
See this topic on discourse.org for more formatting options.
Thank you so much for helping. Appreciate it
Hello, I am using the script above.
My question is can I import the .csv file to the Table Row 1 instead of the header.
I am using the power table. The header data get replaced every time.
FYI, my csv file does not contain header name.
I do not want the data to overwrite my table header.
Crossposting is not allowed. Answer in the other thread.
