How Do I Remove a Property Binding?
I’m trying to remove a property binding. I’ve gone through the IU course on binding, I’ve searched the forms and the docs. Nowhere does it tell you how to remove a property binding or any other for that matter. Maybe it’s so obvious that there’s no need, but I don’t see it.
Look for “No Binding” button underneath the binding types at the left of the property binding window (if your window isn’t tall enough you won’t see it, so stretch your property binding window taller if needed). Tap it and then OK on the property binding window and any binding should be removed.
That worked. Seemed to me I had tried that because it’s right there in the property binding window but it didn’t seem to work. Probably lack of patience on my part.
Thanks for the help
