How do I stop the Ignition gateway from starting automatically on Linux
Each time I restart/power on my machine, the gateway starts up and I don’t want tihs. Can’t find any documentation on disabling this. Thanks in advance
Turns out I just couldn’t grep for the service because I was looking for ‘ignition’ rather than ‘Ignition’ :man_facepalming:
For anyone who needs this:
systemctl disable Ignition-Gateway
It used to be just ignition, and can be configured to still be so. (:
The new service names annoy me, but I think we had to change them, or at least the Windows name, because Dell released some stupid security software that runs under the “Ignition” service name. I guess in response we just changed it across the board to “Ignition Gateway” or “Ignition-Gateway”.
Could the manual be updated to reflect 'Ignition-Gateway' instead of 'ignition'
Linux
You can control the service using the ignition.sh script. It can be called with the start and stop parameters to perform the relevant operations.
For example:
/usr/local/bin/ignition/ignition.sh start
Additionally, you can use native terminal commands to start or stop the service:
service ignition start
service ignition stop
https://docs.inductiveautomation.com/display/DOC81/Gateway
@Paul.Scott
