How do I write a indirect tag write tag script?
How do I write a indirect tag write tag script? I am having trouble with the above example.
Thanks!
You just build your tag path as a string and use that in the system.tag.write call.
system.tag.write(myBuiltTagPath, valueToWrite)
Does it make a difference on what type of button I use to script it to?
It does matter, for general purposes a button will be ok. If writing to a PLC, for example, is advisable to use another type of button. You can always look up in the user manual.
And scripts should work ok independently the button type.
