How do you sort a dataset
I am collecting data from various Lines and Machines and storing it in multiple tables. I often want to display this data on a window using a table where the column headings of the database table are in one column of a dataset and the value is in the next column. Basically I want to turn the table on it’s side.
I have the following function in a module that I call when I need to do this. This is working very well but I would like to sort the column names.
I would like to either sort by column name at the query definition or within the function. Is there a simple way to do this?
def turnTableSideways(ds): import fpmi headers = [] for c in range(ds.getColumnCount()): headers.append(ds.getColumnName(c)) pyNewData = [] pyOldData = fpmi.dataset.toPyDataSet(ds) for x in range(len(headers)): strDetail = str(pyOldData[0][x]) pyNewData.append([headers[x],strDetail]) dsSideways = fpmi.dataset.toDataSet(["Item","Value"],pyNewData) return dsSideways
Thanks,
Sorry, I should have searched the net for this first.
I added pyNewData.sort() to the existing code.
def turnTableSideways(ds): import fpmi headers = [] for c in range(ds.getColumnCount()): headers.append(ds.getColumnName(c)) pyNewData = [] pyOldData = fpmi.dataset.toPyDataSet(ds) for x in range(len(headers)): strDetail = str(pyOldData[0][x]) pyNewData.append([headers[x],strDetail]) pyNewData.sort() dsSideways = fpmi.dataset.toDataSet(["Item","Value"],pyNewData) return dsSideways
Glad you got it working.
For what its worth, I would like to add a rotateDataset() and sortDataset() function to the system.dataset library.
