Hello
I want to put some string into the params property of a view. the problem is because property doesn’t have type, if the value is a number the value interpret as number, but I want in some cases it read as string it doesn’t work. putting “” around value add those “” into string itself.
For example put 123 -> 123 number
‘123’ - > ‘123’ string not 123 string
I want this: 123 -> 123 string
You could use a property change script:
if (previousValue is None) or (currentValue.value != previousValue.value):
self.custom.key = str(currentValue.value)
Two things before you do this:
- the value comparison is important to prevent infinite loops because previousValue and currentValue will always have different timestamps and so will never be equal, whereas their values could be.
- the check against previousValue being
Noneis important because the first time the change event occurs there is no “previous value”.
