How friendly are svg with updates?
Hi!
I'm starting to use svg to small things in our project.
It all started when I discovered this.
Just wondering how update friendly are those things. Not saying they break, but what about missalign or things like that.
Thx!
IA doesn't control the SVG standard, so as long as the SVG works in a previous version it should continue to work in newer versions. If it doesn't I would consider that to be a bug, as IA's support of an SVG feature would have stopped working. However, that doesn't necissarily mean it is a bug in IA's software.
How they align, is more of a CSS feature, and the same is true of the CSS standard.
I have had no issues with SVG's that work, not working in newer versions.
Thanks!
To add to this, I would consider embedded SVGs as stable as you would embedded PNGs or even Label components. I have never considered them for an ignition upgrade
