How I can access to mouse events in each sub-item of horizontal menu
I want to change the color of my text when the mouse is over that sub item, for example:
When the mouse is over "Resumen de eventos" I want it to change the color of the text, I am having trouble accessing the event of each item.
Thanks in advance!
Which component(s) are you using?
I'm using "Horizontal Menu":
You could accomplish this with theming through adding the following CSS to a custom there.
.ia_horizontalMenuComponent__item:not(.ia_horizontalMenuComponent__item--active):not(.ia_horizontalMenuComponent__item--disabled):hover {
    color: red;
