Hello
How I can create screens with a resolution general.
The problem I have is that I have a server in the resolution, but when a client wants to access the SCADA from your machine, change the resolution, the screens are smaller.
I can do?
regards
Hello
I can do?
regards
You want to develop your screens at the smallest resolution in the designer so it can scale up nicely in the client. Our resolution is based off an aspect ratio. So if you develop for a wide-screen it will not look the same on a standard (box) screen. Just make sure the aspect ratio is the same from the designer to the client.
