I have a view with an input param called path.
For that view I need to display the path with a property that is inside the path.
Let me give an example:
If path is [default]folder1/folder2/folder3
The property that I need is [default]folder1/folder2/folder3/id.
Then I get the value from path and the value from id and display it together.
Like this: [default]folder1/folder2/folder3/D-IA-001 (for example)
I could think of 3 ways of doing this. I'm looking what is the best way or the intended way.
Indirect binding
I create a custom property with the indirect tag. Like this:{view.params.path}/id. This would return the value ofid.
Then in another custom propery I create an expression binding. Like this:{view.params.path} + "/" + {view.custom.id} -
system.tag.readBlocking()
I create a custom property with a binding to{view.params.path}. Then I create a transform script with a code that look like this:
id = system.tag.readBlocking(value)
if id.quality.isGood():
return value + "/" + id.value
return "ERROR"
- tag() expression
I create a custom property with an expression structure.
Inside I create 2 values{view.params.path}and the other onetag({view.params.path} + "/id")
Then I simply combine the 2.
However, I belive that the use oftag()is not recommended.
I'm asking this because we have a flex repeater that generates about 20-30 views that need this data. We are having loading problems and we are trying to understand why.
Any help or tip is appreciated.
Thx!
