How to access database data read/write by Central standard ignition gateway connected with Ignition edge
I am connected my ignition edge with standard ignition gateway as remote provider able to read/write values to ignition edge tags how to link these tags with database connected in standard version
You'll need to use the SQL Bridge module to directly link tags to the DB, or if you only need read only access of data you can use query tags. These all need to exist on the standard edition though.
Is this the right question? Perhaps your application should not be using Edge.
Thank you for suggestions, will check for other options.
