I am new to docker with docker desktop.
I learned up to the point of creating volumes using docker compose.
My intention is to run multiple instances of ignition for development purpose, along side with git practices. On this note I need to access project folder of the individual ignition instance (is instance even the correct term to use here?)
How do I access the individual project folder from windows explorer?
I personally use a linux style terminal running bash so I can use the same commands I'd use on linux. Then it's easy:
docker exec -it {container} bash
Note that IN docker desktop, there's a "Volumes" menu entry which allows you to browse your volumes. Never used that, so I can't say what you can do with it, but it's there.
Yes, Docker Desktop also has a Volumes section. You can browse all files stored in the Stored Data section within that.
Additionally, you can add files to a volume or save files from a Docker volume to your PC.
Thanks all.
For the record, I learned this
docker volume ls will display all volumes
docker volume inspect will tell you where the volume is mounted (in linux form)
To find the equivalent windows loc:
Enter \\wsl$in window explorer. Somehow is equivalent to \\wsl.localhost
The volume can be found at window explorer:
\\wsl.localhost\docker-desktop\mnt\docker-desktop-disk\data\docker\volumes
I am curious though, it is mounted as network drive in windows? this location should be somewhere in drive C.
