Hi All,
I’m looking for some help with alarm. I like to Acknowledge alarm using physical input from PLC.
I don’t know if that is possible.
Thanks in advance
Hi All,
Thanks in advance
Thanks Matrix_Engineering…
I did this last week for some in-house function blocks we made for Phoenix’s PLCNext controllers. I put this in the Value Changed script for our Ack bit in the UDT. It might be a little messy and I’d welcome any input on improving it!
if currentValue.value > previousValue.value:
aTag = tagPath
#Get the alarm name from the tag path
aSource = aTag.replace('[default]', '')
aSource = aSource.replace(tag.name, '')
aSource = '*'+aSource+'*'
#alarmJournalName is a parameter in the UDT. If you have a static one use it here instead
alarm = system.alarm.queryJournal(
journalName = system.tag.read('[.]alarmJournalName').value,
state = ["ActiveUnacked"],
source = [aSource]
uuidList = []
#This will get every instance of the active, unacked alarm in the journal for your alarm
for x in alarm:
uuidList.append(str(x.getId()))
system.alarm.acknowledge(uuidList, '', "admin")
Hopefully this helps!
Hi rbabcock
Thanks for the script. I will check that and let you on the same.
Tamil
