hi all, I am trying to correct the layout to a 14'' screen resolution, any recommendations?
I am using a Container Coordinate
Hi Miguel_Cimildoro,
In the designer, if you click on the Coordinate Container you will see a property called mode. Change that to percent and then set an aspect ratio, maybe 1:1. See how that translates to your 14" screen resolution session. Maybe you need to use a different kind of container.
It's hard to tell exactly what needs to be corrected here, so I would recommend reaching out to * Inductive Automation Support so they can remote in and take a look.
thank you very much, it was just the configuration I wanted to try.
regards
