I'm trying to add a new boolean field to a device config record. I'd like this field to have a default value of true for existing devices. When creating a new device, I'm not passing the device config record as a parameter, I'm passing an interface, which I've made my record implement, so I'm grabbing the value using a method like
boolean isEnabled() {
return category.newfield
If I'm creating a new device with this field, the new record gets created with newfield, there's no problem. Surprisingly, this returns a false for existing records, which makes a kind of sense, newfield doesn't exist in that record. Is there a way for me to detect whether newfield exists on an existing record without diving into the resource folder? For example, if I wanted to add a new column in a PersistentRecord in 8.1, I think I just needed to define the field with a default and that was it.
ExtensionPoints have a getSettingsUpgrader() method on them you could use for this.
e.g.
public record WidgetConfig(String name, int width, boolean enabled) {
* Upgrade a WidgetConfig JSON object: existing records that predate the
* "enabled" field should default to true.
public static JsonElement upgrade(JsonElement configJson) {
if (configJson instanceof JsonObject obj && !obj.has("enabled")) {
obj.addProperty("enabled", true);
return configJson;
and in the ExtensionPoint:
@Override
public Optional<JsonSettingsUpgrader> getSettingsUpgrader() {
return Optional.of(WidgetConfig::upgrade);
Keep the upgrade method idempotent since it runs on every load; introduce a configVersion field or something once the upgrade logic gets complex enough that idempotency is hard to guarantee.
Thanks Kevin, that did the trick. For anyone following up, these methods are available starting in the 8.3.3 API. The methods here don't write the new setting to disk, but they do appear to inject the new property into the json object before it's used anywhere.
