hello, I am trying to add all our motor status opc tags to block items in transaction group. There are over 500 of them. We will use them for report generation/ I am wondering instead of manually found them and add them one by one, is there any quicker way to do it? thanks
You can export the transaction group to XML and then edit with an external tool. I find that to be much more efficient.
thank you i will try that!
If your tags are in folders, you can also drag the folder into the transaction group.
they are in folder, just we only want partial of each folder, and kinda need to do manually
