I try to add some custom Properties into an AbstractVisionComponent
just like we do in the designer : Righ Click \ Customizers \ Custom Properties.
I’ve seen we can add “static” properties in the HelloWorldComponentBeanInfo.java (in project ComponentExample_Designer)
but I need dynamics properties which are created when the component is dropped on a windows in the designer.
Could you please provide a sample of code for adding a Custom Properties and for changing is value.
(code to add into the AbstractVisionComponent).
I added a property “title” using the code below. I can bind a string tag to it in the designer and surprise, surprise it worked.
I apologize if I have misunderstood your question.
public ChartComponentBeanInfo() {
super(ChartComponent.class, DynamicPropertyProviderCustomizer.VALUE_DESCRIPTOR, StyleCustomizer.VALUE_DESCRIPTOR);
@Override
protected void initProperties() throws IntrospectionException {
// Adds common properties
super.initProperties();
addProp("title", "Title", "The title of the chart", CAT_DATA, PREFERRED_MASK | BOUND_MASK);
