I have a report generated using a Dataset of stats from machine lines & operations. This info is generated and displayed in Table. I'm looking to add a Pie Chart to certain parts of that table.
Here is an example section of some of the data in the Data Key on the table:
On the report, there's a single table that groups by the Line Name and then outputs various info about each OP. Here's a picture of the Table Grouping as well as a snippet of what that report Preview looks like:
Preview Report:
This is great, but the next thing I'm trying to do is:
- Use a custom Version Key to identify certain OPs, that we want to show more info for.
This part is done and I can now identify and change the format on certain OPs. Here shows how B1 OP is identifed and sized differently:
Problem/Need
2) I want to put a Pie Chart inside this '08 - B1' section that has Keys 'Discharge' and 'Spoilage' found in the Data Key / Dataset header, then the values of that Pie Chart are the values inside the row in those respective columns.
I can't seem to figure out how to make this work. I think Pie Charts want to use a column as a Key and another column as Values, but I want to use my column names as Keys, then use the values in the row for that OP to be the values in the pie chart.
Hopefully that makes sense!
