How to add sepasoft modules to igniton gateway
Hi I am a new user from China. I just downloaded ignition and installed. I also want to try sepasoft MES modules. How to add sepasoft modules into ignition. Anyone can help? Thanks a lot!
Welcome!
You’ll need to download from the 3rd-party section of the Ignition download pages. Make sure you pick compatible versions. (If the site doesn’t show any for the exact version, you can usually try the most recent available version.)
After you’ve downloaded, in your own gateway, log in and navigate to “Config” => “System” => “Modules”, then click on the link at the bottom that says “Install or Upgrade a Module…”. Use that page for each SepaSoft module you downloaded.
Thank you very much! It works and I installed the modules following your instruction. Appreciated~
