i added s71500 device to ignition,and showed me status is connected. then opened ignition designer to add tags. i am confused about OPC ITEM PATH, what exactly does it mean? could you show me an example on adding tags which link I,Q,M,T,DB
Not sure. Sounds like one of the communications restrictions you have to relax in the S7 processor. I’ll let one of the Siemens fans take it from here. (-:
