How to Add Textbox Filters Below Each Table Header
Hi Team,
We need to add a filter textbox below each column header in the table.
The built-in filter functionality is working, but the client specifically requires a separate textbox below each column header.
One possible approach is to create a separate row above the table and use it as a container for the filter textboxes. However, if the table columns are resized (expanded or reduced), the textboxes may lose alignment with their respective columns.
What would be the best way to implement this while ensuring the textboxes remain properly aligned with the table columns?
I would be grateful for your suggestions and support.
Thanks in advance!
I don't have an exactly fitting solution, and I'm not sure if others even approve of this behavior, but this is what I would do:
  • Create one container to your liking.
  • Insert two tables in the container, with the exact same sizing settings.
  • Use the first table to show your headers.
  • Create a separate view showing just a textbox.
  • To the first table, add one data row where each column displays a view. (This can be done by setting the Render to View and adding a viewPath to a pre-made view.). Link this viewpath to the textbox view you just made.
  • Add the data you want to display to the second table.
  • Set enableHeader in the second table to False.
It's not the cleanest, I'm aware, but I wouldnt see how else I would solve this.
Please edit your question title and add the appropriate Ignition version tag. The answer may depend on your version.
@JVDM's answer doesn't address tracking the column widths between the two tables. The adjusted column width does not appear in the table's properties so I can't see how it could be transferred from one table to the other without doing some fancy Javascript injection.
There just might be some way to increase the header height and CSS float the text fields in relative to the bottom left of each column header cell and with the same width.
We have added the filter functionality using a Flex Container placed above the Table.
However, we are facing another issue with the horizontal scrollbar. When the user scrolls horizontally, only the table data moves, while the filter/header section remains stationary.
How can we hide only the horizontal scrollbar while keeping the vertical scrolling functionality?
The view structure is as follows:
  • Both the header and table containers are placed inside a common parent container.
  • The filter/header section is positioned above the table.
We would appreciate your suggestions on how to resolve this issue.
