How to best collect information from an LMS software and show it on Ignition
Hello everyone, I'm looking for a solution to display information from an LMS (Learning Management System) into Ignition, has anyone already worked with that? Which LMS software did you use? How did you managed to pull the data out of the software?
Thank you in advance for your help!
The answer to "how to best collect information" is going to depend heavily upon your choice of software, I imagine. And how you envision displaying this information in Ignition - for instance, using Vision, or Perspective?
Yes, I was checking to see if someone already worked on something similar. the LMS software is not set in stone yet, so if someone had a recommendation I would gladly hear it. I'm going to display it on Perspective, and thanks for the reply!
