I want to bind a tag to a numeric text field dynamically,for example,bind a tag {mine/ne_pa1-6/ne_pa1} ,and from some condition ,bind tag{mine/ne_pa1-6/ne_pa2}
Thank you
Thank you
You can use the expression binding to accomplish that. Just bind the numeric text field to the following expression:if(something = value, {_mine_/ne_pa1-6/ne_pa1}, {_mine_/ne_pa1-6/ne_pa2})You just have to replace the something = value with an expression that returns the first tag if true and the second if false. Hope this helps.
