How to calculate avg on time and off time of the machine?
Hello friends,
I installed a sensor for monitoring AC status. It gives me a value of 1 or 0 when the AC is on or off. So, I log that value(0/1) in the database using the transaction group. I want to calculate the total working hours and non-working hours when the AC is on or off. Also, AC data is required to be reported.
How to calculate the working time and non-working time of AC?
Sample report format for reference.
I want the that report daily basis.
I want to log data at specific scheduled times. For example (21:00 PM to 8:00 AM)log time. At this point, the sensor data should be logged into the database.
So, how to log data using transaction group a by specific time?
Regards& Thanks,
Govind Suthar
Transaction groups have a schedule option. See below.
https://docs.inductiveautomation.com/display/DOC81/Understanding+Transaction+Groups#UnderstandingTransactionGroups-Schedule
There's an IU video link on that page and that might give you some ideas.
Referencing this question:
If you are logging the AC every 20 minutes (as in your sample), then you can multiply the value count by 20 and have the same granularity.
select log_id,
       CASE WHEN value = 1 THEN 'ON' ELSE 'OFF' END AS status,
       COUNT(value)*20 as minutes
from my_table
group by value, log_id
Is it possibale without using transaction group?
Yes, it's possible, fairly simple and very powerful. See my posts in Durations for certain tag value.
I took the value from the database. Data is not logged using tag history.
Can you give a query and how to implement?
If the log interval not fixed then how to work it?
What database are you using? MySQL / MariaDB / MS SQL, etc.?
MySQL Databse
where to to run this script?
Use your database's lead() or lag() function to pull a value from the adjacent row for you to compute time deltas (right in the SQL), then sum the time deltas that correspond to on-time.
You mentioned report in your first post, are you using the reporting module? Or just a table on a view/window?
Yes, I use a report module
OK, so then that SQL query goes here:
