How to call project library script
I created a script to initialize state in my scripting project library
The script library is called InitState and the function inside is also def InitState():
I can run the script in script console so no error there.
Problem is I try to launch when they press the start button and I keep getting an error:
Error executing script for event: actionPerformed on component startGA
ManualLine is my project name - error traceback is below.
do I need to do something else to make this script accessible to the button?
Button script is:
  window = system.nav.openWindow('GA1')
  system.nav.centerWindow(window)
  ManualLine.InitExtRangeWorkFlow.InitExtRangeWorkFlow
File "event:actionPerformed", line 8, in
NameError: name 'ManualLine' is not defined
at org.python.core.Py.NameError(Py.java:259)
at org.python.core.PyFrame.getname(PyFrame.java:257)
at org.python.pycode._pyx185.f$0(<event:actionPerformed>:8)
at org.python.pycode._pyx185.call_function(<event:actionPerformed>)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.Py.runCode(Py.java:1703)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:804)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:207)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:300)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
at jdk.proxy2/jdk.proxy2.$Proxy61.actionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.base/java.security.AccessController.doPrivileged(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Ignition v8.1.43 (b2024082010)
Java: Azul Systems, Inc. 17.0.11
Don't include the project name. Projects cannot call library scripts of other projects.
Thank you so much! I am new to this tool and I was making a nice dent in the wall banging my head into it over what I new must be simple syntax.
