Hello!
I am having an issue catching a named query error. I can see the error if I'm in the named query editor while testing but if I try to duplicate the same error in the actual application my try catch does not seem to work. I have tried to implement other similar solutions on this forum like Try Catch Block is not Working for any query type like NamedQuery - Ignition - Inductive Automation Forum and some others. However, they don't seem to work for me.
I am not trying to catch a specific error I just want to throw a popup for my user with the reason. I will show my code and named query below.
SCRIPT:
def runAction(self, event):
RC = self.parent.getChild("FlexContainer").getChild("FlexContainer").getChild("FlexContainer_0").getChild("EmbeddedView_0").props.params.CurrentText
ICP = self.parent.getChild("FlexContainer").getChild("FlexContainer").getChild("FlexContainer_1").getChild("EmbeddedView_0").props.params.value.iconPath
DC = self.parent.getChild("FlexContainer").getChild("FlexContainer").getChild("FlexContainer_2").getChild("EmbeddedView_0").props.params.value.color
name = self.parent.getChild("FlexContainer").getChild("FlexContainer").getChild("FlexContainer").getChild("EmbeddedView_0").props.params.CurrentText + '-'+str(self.view.params.CellSuffix)
RDT = self.parent.getChild("FlexContainer").getChild("FlexContainer").getChild("FlexContainer_3").getChild("EmbeddedView_1").props.params.SelectedOption
PDT = self.parent.getChild("FlexContainer").getChild("FlexContainer_0").getChild("FlexContainer").getChild("EmbeddedView_0").props.params.SelectedOption
OS = self.parent.getChild("FlexContainer").getChild("FlexContainer_0").getChild("FlexContainer_0").getChild("EmbeddedView_1").props.params.SelectedOption
SRO = -1
STID = self.parent.getChild("FlexContainer").getChild("FlexContainer_0").getChild("FlexContainer_2").getChild("EmbeddedView_0").props.params.SelectedOption
DCC = self.parent.getChild("FlexContainer").getChild("FlexContainer_0").getChild("FlexContainer_3").getChild("EmbeddedView_0").props.params.SelectedOption
params = {'LineID':self.view.params.LineId,'ReasonCode':RC,'IconPath':ICP,'DisplayColor':DC,'Description':name,'AltCode':-1,'RDT':RDT,'PDT':PDT,'OS':OS,'SRO':SRO,'STID':STID,'DCC':DCC}
system.perspective.print(params)
try:
output = system.db.runNamedQuery('Cells/AddCellState', params)
system.perspective.print(output)
except java.lang.Throwable, e:
if "Cannot insert duplicate key in object" in str(e.cause):
pass
else:
raise e
except Exception as e:
print("Error details:", str(e))
Named Query:
EXEC [config].[stp_addEditLineState]
@LineID = :LineID,
@ReasonCode = :ReasonCode,
@IconPath = :IconPath,
@DisplayColor = :DisplayColor,
@Description = :Description,
@AltCode = :AltCode,
@RecordDowntime = :RDT,
@PlannedDowntime = :PDT,
@OperatorSelectable = :OS,
@SubReasonOf = :SRO,
@StateTypeID = :STID,
@DowntimeCategoryCode = :DCC
The specific error I was testing in my named query test was having duplicate reason codes. my database has a column constraint to prevent duplicated reason codes. So '@ReasonCode'('RC' in script) cannot be a duplicate.
EDIT: my stored procedure has no error handling; I have also verified the named query works as long as there is no duplicate key error
