How to Change Line Color in Tree View Object (Vision)
Hi!
In the Tree View object in Vision, how can I change the color of the lines that connect folders? Is there a specific setting or method to customize their appearance?
These can be changed through the look and feel using these properties:
'Synthetica.tree.line.color.horizontal'
'Synthetica.tree.line.color.vertical'
Example:
from javax.swing import UIManager
UIManager.put('Synthetica.tree.line.color.horizontal', system.gui.color('green'))
UIManager.put('Synthetica.tree.line.color.vertical', system.gui.color('green'))
Result:
Thank you! The solution worked perfectly.
