How to Change Local Time in Ignition Gateway
Hello Guys , I have an issue with the Local time i want to change it. See Below.
image.
I found some information how to change it from the ignition.conf file . but my config file looks like this in the Java Additional Parameters
Note that my Designer is installed on windows and the gateway is installed in Linux.
You can add wrapper.java.additional.X=-Duser.timezone=America/Los_Angeles to your Ignition.conf to change the timezone. Note the X after additional, you need to change that to whatever number parameter is next, in your case it looks like 7. After adding this you have to restart your gateway.
This is the perfect solution for all the disalignments of the components, and project settings. Works even when developing on docker containers
