I'm trying to follow this guide but got stuck on a few things.
Ignition Perspective: How to embed views in a table
First I had to redo the embedded View as I'd not selected the Flex Container type. I could not find a way to change it. You can copy the JSON info from the old View but then the objects still have the old none flex settings.
To get it to look like a text field or dropdown is not a separate object in the table you need to add styles to the dropdown object. Under TextField and Dropdown PROPS style I added, backgroundColor: #00000000 and border: none
I have a perspective table that is currently using an onEditCellCommit script to update a tags property by changing the text in any cell in a column. It gets the tags path from the only other column.
I was thinking I'd just be able to pass the new value from the view into the tables cell and trigger the same onEditCellCommit script that is already there but I did not have any luck. I also tried moving the script in the onEditCellStart script.
I ended up moving the onEditCellCommit into the Message Handler script and it's working with the TextField view.
Testing with a TextField in the view I can see the current value in cell just as though the TextField view was not there. This is what I already had without the view, the column was set to editable and the onEditCellCommit script updated the dataset but I'm wanting to use a Dropdown view in each cell with a list of options.
The TextField used the expression binding but the example skips over the Dropdowns, value and options bindings.
I can't get the options or the current value into the Dropdown view.
I tried to use the same binding as the TextField, text for the Dropdown, data but even if I don't use a binding at all and just hard code the value as "test" it still just shows "Select...".
For the Dropdown options, the example shows the columns options under viewParams as a dataset but I can't seem to set it as a dataset.
