How to change the domain login in gateway Ignition?
I changed the Login and Password in Gateway to Domain Login by creating a new Identity Provider Security Assertion Markup Language 2.0. However, I entered the wrong settings and certificate due to which I can't get into Gateway now....
How can I fix it/restore login with login and password?
Best regards,
Michał
https://docs.inductiveautomation.com/display/DOC81/Gateway+Command-line+Utility+-+gwcmd#GatewayCommandlineUtilitygwcmd-GatewayPasswordReset
I highly recommend that you set the identity provider to fallover to the Ignition default user source. The default user source then only needs the Administrator user and you'll have some way of gaining access again in the event of the main IdP failing or a password mix-up.
Thank you!
