Hello, everyone. How to change the project directory? I’d like to save project data to another partition rather than the default one, but I don’t know how. Any help will be appreciated.
Hey,
I am too looking for this approach to check if ignition does not lag much. Is there a way?
You can do this on Linux by mounting another filesystem at the project directory.
My condolences if you are not using Linux.
Though I agree with @pturmel, I will mention that you should be to either symlink or mount a device directly at a folder location (instead of a drive letter) even on Windows.
You can modify the data dir in the ignition.conf file, however this would include the entire data dir, not just hte project folder.
