How to check if a value is inside an array in the expression tag editor?
Hello Forum,
in my expression tag, I need my tag to have this value:
Let's say I have a value x and I want to check it if it's inside an array or no.
so basically the expression will be:
x in myArray
how can I do that in my expression tag?
Thank you
Did you try lookup()?
Hadn't tested it and not sure about your tag type.
If it's a string array (it maybe works with other array types as well, haven't tested this) and your gateway version is 8.1.8+, you could use the expression function indexOf.
thank you for your response, I already tried this one and it didn't work, my array in a hardcoded array of integers
if it's hardcoded, consider using a dataset tag with a lookup() expression.
indexOf is absolutely the solution here and works regardless of array/list type as long as the value you're looking up also matches that type.
