I’ve been trying to find the best way to check to see if a file is open. This is what I’ve come up with so far:
import os
filepath = "\\\\c:\\TST\\MyFile.txt"
isOpen = None
file_object = None
if os.path.exists(filepath):
try:
print "Trying to open %s." % filepath
buffer_size = 8
# Opening file in append mode and read the first 8 characters.
file_object = open(filepath, 'a', buffer_size)
if file_object:
print "%s is not open." % filepath
isOpen = False
except IOError, message:
print "File is open (unable to open in append mode). %s." % \
message
isOpen = True
finally:
if file_object:
file_object.close()
print "%s closed." % filepath
else:
print "%s not found." % filepath
print isOpen
The code above works great when it is used on a button, but when it is implemented in the shared scripts file like this:
import os
def isOpen(filepath):
isOpen = None
file_object = None
try:
buffer_size = 8
if file_object:
isOpen = False
message
isOpen = True
finally:
if file_object:
file_object.close()
else:
return isOpen
The following error occurs:
File “event:actionPerformed”, line 26, in
File “module:shared.file”, line 13, in isOpen
TypeError: open() takes exactly 1 argument (3 given)
We are using:
Ignition 7.9.0 (b2016101208)
Windows Server 2012R2
Java 1.8.0_111-b14
Any help would be great!
