How to Configure Multiple values in X axis - XY Chart
I want to add 2 values in X-axis against Multiple Y-axis values.
I tried one of the Y-axis value with 2 X-axis Values but I can't see my expected output.
so how can I plot the 2 X-axis values with Multiple Y-axis values in XY chart?
Can you post the props json that you trying to get working? (you can format it for the forum with three backticks before and after the pasted json)
Actually i'm doing query binding for datasource.
are you asking about datasource props?
Datasource, series, xaxis, yaxis props will all matter. You could also copy the component itself and paste the raw json in here, but provide an example datasource props as well if you go that route. In both cases you should paste it in with preformatted text option:
We can't tell you why your chart isn't working if we don't know how you've configured it.
Have you seen this example: XY Chart Example - Candlestick Chart - Ignition User Manual 8.1 - Ignition Documentation?
@djs Here is my Config props. i split the props due to forum limitation
    "type": "ia.chart.xy",
    "version": 0,
    "props": {
      "title": {
        "text": "Multiple Axis",
        "appearance": {
          "color": "#FFFFFF",
          "font": {
            "size": 25,
            "weight": 500
          "padding": {
            "top": 10,
            "bottom": 10,
            "left": 10,
            "right": 10
      "subtitle": {
        "appearance": {
          "font": {
            "weight": 700
      "legend": {
        "position": "top",
        "markers": {
          "width": 50,
          "height": 50,
          "stroke": {
            "color": "#FF4747"
        "labels": {
          "font": {
            "weight": 500,
            "size": 25
      "enableTransitions": true,
      "selection": {
        "selectedHighlightColor": "#000000"
      "background": {
        "render": "color",
        "color": "#000000"
      "xAxes": [
          "name": "time",
          "label": {
            "enabled": true,
            "text": "Time",
            "color": "#D5D5D5"
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "render": "date",
          "category": {
            "break": {
              "enabled": false,
              "startCategory": "",
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": false,
              "timeUnit": "hour",
              "count": 1,
              "skipEmptyPeriods": false
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "inputFormat": "M/d/yyyy",
            "format": "d/M"
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "logarithmic": false,
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
            "format": "#,###.##"
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1,
              "rotation": 0,
              "verticalCenter": "middle",
              "horizontalCenter": "middle"
            "grid": {
              "color": "",
              "opacity": 1,
              "dashArray": "",
              "minDistance": 60,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
          "appearance": {
            "font": {
              "size": "",
              "weight": 500
            "grid": {
              "color": "",
              "dashArray": "",
              "minDistance": 60,
              "opacity": 1,
              "position": 0.5
            "inside": false,
            "labels": {
              "color": "",
              "horizontalCenter": "middle",
              "opacity": 1,
              "rotation": 0,
            "opposite": false
          "category": {
            "break": {
              "enabled": false,
              "endCategory": "",
              "size": 0.05,
              "startCategory": ""
          "date": {
            "baseInterval": {
              "count": 1,
              "enabled": false,
              "skipEmptyPeriods": false,
              "timeUnit": "hour"
            "break": {
              "enabled": false,
              "endDate": "",
              "size": 0.05,
              "startDate": ""
            "format": "M/d",
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
          "inversed": false,
          "label": {
            "color": "",
            "enabled": true,
            "text": "Shift"
          "name": "Shift",
          "render": "category",
          "tooltip": {
            "background": {
              "color": "",
              "opacity": 1
            "cornerRadius": 3,
            "enabled": true,
            "pointerLength": 4,
            "text": ""
          "value": {
            "break": {
              "enabled": false,
              "endValue": 100,
              "size": 0.05,
              "startValue": 0
            "format": "#,###.##",
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
          "visible": true
      "yAxes": [
          "name": "data1",
          "label": {
            "enabled": true,
            "text": "data1",
            "color": "#FFFF8A"
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "render": "value",
          "category": {
            "break": {
              "enabled": false,
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": false,
              "timeUnit": "hour",
              "count": 1,
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "format": "M/d/yyyy HH:mm:ss"
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1,
              "rotation": 0,
            "grid": {
              "color": "",
              "opacity": 1,
              "dashArray": "",
              "minDistance": null,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
          "appearance": {
            "font": {
              "size": "",
              "weight": 500
            "grid": {
              "color": "",
              "dashArray": "",
              "opacity": 1,
              "position": 0.5
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1,
              "rotation": 0,
            "opposite": false
          "category": {
            "break": {
              "enabled": false,
              "endCategory": "",
              "size": 0.05,
              "startCategory": ""
          "date": {
            "baseInterval": {
              "count": 1,
              "enabled": false,
              "timeUnit": "hour"
            "break": {
              "enabled": false,
              "endDate": "",
              "size": 0.05,
              "startDate": ""
            "format": "M/d/yyyy HH:mm:ss",
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
          "inversed": false,
          "label": {
            "color": "#00FFFF",
            "enabled": true,
            "text": "data2"
          "name": "data2",
          "render": "value",
          "tooltip": {
            "background": {
              "color": "",
              "opacity": 1
            "cornerRadius": 3,
            "enabled": true,
            "pointerLength": 4,
            "text": ""
          "value": {
            "break": {
              "enabled": false,
              "endValue": 100,
              "size": 0.05,
              "startValue": 0
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
          "visible": true
      "series": [
          "name": "series_1",
          "label": {
            "text": "Time-data1"
          "visible": true,
          "hiddenInLegend": false,
          "defaultState": {
            "visible": true
          "data": {
            "source": "example",
            "x": "time",
            "y": "data1"
          "xAxis": "time",
          "yAxis": "data1",
          "zIndex": 0,
          "tooltip": {
            "enabled": true,
            "text": "{name}: [bold]{valueY}[/]",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "render": "line",
          "candlestick": {
            "open": {
              "x": "",
              "y": ""
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "deriveFieldsFromData": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "column": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "width": null,
              "height": null,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "line": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 5,
                "opacity": 1,
                "color": "#FFFF8A",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": false,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "stepLine": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "_1": "Shift"
          "name": "series_2",
          "label": {
            "text": "Shift-data1"
          "visible": true,
          "defaultState": {
            "visible": true
          "data": {
            "x": "Shift",
            "y": "data1"
          "xAxis": "Shift",
          "yAxis": "data1",
          "zIndex": 0,
          "tooltip": {
            "enabled": true,
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "render": "line",
          "candlestick": {
            "open": {
              "x": "",
              "y": ""
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "column": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "width": null,
              "height": null,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "line": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 5,
                "opacity": 1,
                "color": "#FF8A8A",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": false,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "stepLine": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "_1": "Shift"
          "_1": "Shift",
          "candlestick": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "stacked": false,
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "open": {
              "x": "",
              "y": ""
          "column": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "height": null,
              "stacked": false,
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "width": null
            "open": {
              "x": "",
              "y": ""
          "data": {
            "x": "time",
            "y": "data2"
          "defaultState": {
            "visible": true
          "label": {
            "text": "Time-data2"
          "line": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": false,
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
              "connect": true,
              "fill": {
                "color": "",
                "opacity": 0
              "minDistance": 0.5,
              "stroke": {
                "color": "#00FFFF",
                "dashArray": "",
                "opacity": 1,
                "width": 5
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "name": "series_3",
          "render": "line",
          "stepLine": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
              "connect": true,
              "fill": {
                "color": "",
                "opacity": 0
              "minDistance": 0.5,
              "stroke": {
                "color": "",
                "dashArray": "",
                "opacity": 1,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "tooltip": {
            "background": {
              "color": "",
              "opacity": 1
            "cornerRadius": 3,
            "enabled": true,
            "pointerLength": 4,
          "visible": true,
          "xAxis": "time",
          "yAxis": "data2",
          "zIndex": 0
          "_1": "Shift",
          "candlestick": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "stacked": false,
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "open": {
              "x": "",
              "y": ""
          "column": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "height": null,
              "stacked": false,
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "width": null
            "open": {
              "x": "",
              "y": ""
          "data": {
            "x": "Shift",
            "y": "data2"
          "defaultState": {
            "visible": true
          "label": {
            "text": "Shift-data2"
          "line": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": false,
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
              "connect": true,
              "fill": {
                "color": "",
                "opacity": 0
              "minDistance": 0.5,
              "stroke": {
                "color": "#FF47FF",
                "dashArray": "",
                "opacity": 1,
                "width": 5
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "name": "series_4",
          "render": "line",
          "stepLine": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
              "connect": true,
              "fill": {
                "color": "",
                "opacity": 0
              "minDistance": 0.5,
              "stroke": {
                "color": "",
                "dashArray": "",
                "opacity": 1,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "tooltip": {
            "background": {
              "color": "",
              "opacity": 1
            "cornerRadius": 3,
            "enabled": true,
            "pointerLength": 4,
          "visible": true,
          "xAxis": "time",
          "yAxis": "data2",
          "zIndex": 0
      "style": {},
      "dataSources": {}
    "meta": {
      "name": "XYChart"
    "position": {},
    "custom": {},
    "propConfig": {
      "props.dataSources.example": {
        "binding": {
          "type": "query",
          "config": {
            "queryPath": "Chart_1111_Query"
& also, DataSource Props
#NAMES
"time","Shift","data1","data2"
#TYPES
str,"str","D","D"
#ROWS,"5"
2023-01-05,"I","39.689998626708984","19.110000610351562"
2023-01-04,"I","38.43000030517578","18.6200008392334"
2023-01-03,"II","38.43000030517578","18.1299991607666"
2023-01-02,"III","39.689998626708984","19.110000610351562"
2023-01-01,"I","39.060001373291016","18.6200008392334"
I had seen the examples in Ignition user manual but I can't find my case
For your series_4, the data is Shift and data2, but you axes are time and data2. Once I changed the xAxis to Shift, the chart rendered.
How exactly are you expecting this chart to look like? You have multiple values per shift I, which renders a vertical line...
Are you looking for a clustered column chart?
I'm expecting the Line chart like this.
I'm afraid I don't understand what you're looking for. There are only 2 series in that example, and both seem to be only looking at the time for their x-axis. What does the shift axis supposed to mean when combined with the data?
Sorry about this.... above attached component props & Screenshot both are different.
the screenshot is what I'm looking for.... I want to show 3 shifts& a day (Shift & Day Should be in X axis) against multiple Y axis Values.
