I have one project where I have to sue Murrelektronik make Impact67Pro module 54631 directly with Ignition without PLC. is it possible or do I need PLC?
This spec sheet suggests it has ethernet and OPC UA on board... you might be able to connect Ignition directly via OPC UA connection.
To build on what @Kevin.Herron said I'd give this a read
Typically connecting devices directly over ethernet directly with OPC UA is a bit more manual configuration but it can be done! I've been working on a custom PCB that integrates directly with our Ignition gateway over Ethernet and it was a lot of work but it's working amazing now and the devices are basically plug and play which was the end goal!
Hey Kevin, Appreciate your prompt reply.
Hey Spencer, Thank you....
