how i can collect tag from Indusoft scada?
in the Indusoft have build in OPC, OPC HDA, DDE, and TCP/IP
which one that simple communication for me to use in Ignition?
i try to connect to Remote indusoft OPC but always problem.
Thanks for your advice
Connecting via an OPC-UA connection should be the easiest route. I’ve actually tested against Indusoft at the last couple OPC interop events and had no problems.
Do you have your Ignition client certificate installed/registered/trusted with the Indusoft software? What kind of problems are you having?
