Hello Evry body!!!
I look at to connect MariaDb to Ignition. What do I do
Hello Evry body!!!
Is MariaDB installed?
If so then create a database connection to it. I think you can use the MySQL driver to connect to it. Here is a video: https://www.inductiveuniversity.com/video/connecting-to-mysql
Yes, I want to install MariaDB…
MySQL is already there by default in ignition.
I can not apply the same procedure because I do not have MariaDb by default…
It’s goog. it worked. Think you
