Hello Team,
We are working on project at the company where we are trying to connect to MQTT Distributor (MQTT over TLS) installed in Ignition :
- The connection to MQTT (1883) is working good.
- The connection to MQTT over TLS (8883) is working only with MQTT Engine of the Ignition Gateway (Internally)
- The problem is trying to connect to MQTT over TLS/SSL with company certificates.
We have two questions :
- What are the required ports to open between device and Ignition Gateway to ensure this connection (MQTT over TLS/SSL) ? knowing that is secured at the company (it will be good to know if there is other ports to open in addition to 8883) ?
- From the client side (MQTT Transmission), what are the certificates required to ensure the connection with Ignition Gateway in MQTT over TLS ?
Thank you for your help
