I think it is a simple question but I would like to know how I could show the value of that specific tag?
for now I get it by means of a custom property of another window but I need by means of an expression to change that string to the value of that tag in particular.
I tried with tag(concat({Root Container.tagPath} , "/GSC_Racks/Rack_Global_3/Word/Rack_Run_State"))
is there any other alternative or suggestion?
thank you very much
To read an indirect tag path (eg a parameterised tag path), you should be using an indirect tag binding.
For example:
Indirect path:
{1}/GSC_Racks/Rack_Global_3/Word/Rack_Run_State
And link 1 to your root container tagpath
Can you be a little more specific please? I have never used the Indirect Tag method.
An indirect tag binding is basically a parameterized path. You put in place holders (that look like this: {some_identifier}) in the path, and give them values dynamically.
For exemple, in your case, the constant part of the path is /GSC_Racks/Rack_Global_3/Word/Rack_Run_State, and it takes a variable part before that.
So, you make an indirect tag binding and use a path like this:
{prefix}/GSC_Racks/Rack_Global_3/Word/Rack_Run_State
In the parameters list below the path, you now have one called prefix, and you can give it a value. Make this value a binding to {Root container.tagPath}, and you're done.
It'll look something like this:
You can build your path exactly as
@pascal.fragnoud described.
You can also take a look at the page on the manual for indirect tag bindings here:
https://docs.inductiveautomation.com/display/DOC81/Indirect+Tag+Bindings+in+Vision
And i would recommend you to take the Inductive University's
free credential course, but this video should be enough for this topic:
thank you very much, I have seen the videos and documentation about the indirec tags and I have found the solution!
