How to convert JSON back to date object
Does anyone know how to convert this strange date format back to a date object?
        "timestamp": {
            "ts",
            192,
            1760647890223
          "$ts": 1759156706683
The full story is that I load some data from a database to a perspective custom property and it looks fine in the designer. The data comes from an SQL query returned as a dataset, then transformed into a JSON object for later use
When I iterate through the property, I use the .get(“timestamp”) from the row object which returns the strange format above. The issue is when I try to insert data back using runPrepUpdate(), I get an “Unable to decode arguments”…but if I edit this timestamp to have a value that looks like this '2025-09-30T12:00:00Z’, the runPrepUpdate() works just fine.
Here is the error for completeness:
[3, 1.5, {'$ts': 1759233600000L, '$': ['ts', 192, 1760644157017L]}]
Java Traceback:
  File "<input>", line 150, in <module>
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:392)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:268)
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO mytable (tagid, value, timestamp) VALUES (?,?,?), [3,1.5, {'$ts': 1759233600000L, '$': ['ts', 192, 1760644157017L]}], , , false, false)
	at org.python.core.Py.JavaError(Py.java:545)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
	at org.python.core.PyObject.__call__(PyObject.java:477)
	at org.python.core.PyObject.__call__(PyObject.java:481)
	at org.python.pycode._pyx363.f$0(<input>:109)
	at org.python.pycode._pyx363.call_function(<input>)
	at org.python.core.PyTableCode.call(PyTableCode.java:173)
	at org.python.core.Py.runCode(Py.java:1703)
	at org.python.core.Py.exec(Py.java:1747)
	at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
	at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:628)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:616)
	at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
	at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO mytable (tagid, value, timestamp) VALUES (?,?,?), [3,1.5, {'$ts': 1759233600000L, '$': ['ts', 192, 1760644157017L]}], , , false, false)
	... 26 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Unable to decode arguments
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:360)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:334)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
	at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runPrepStmt(ClientDBUtilities.java:293)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:261)
	... 24 more
Caused by: java.io.InvalidClassException: failed to read class descriptor
	at java.io.ObjectInputStream.readNonProxyDesc(null)
	at java.io.ObjectInputStream.readClassDesc(null)
	at java.io.ObjectInputStream.readOrdinaryObject(null)
	at java.io.ObjectInputStream.readObject0(null)
	at java.io.ObjectInputStream.readArray(null)
	at java.io.ObjectInputStream.readObject(null)
	at com.inductiveautomation.ignition.common.Base64.decodeToObjectFragile(Base64.java:985)
	at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.RunPrepStmt.runUpdateQuery(RunPrepStmt.java:43)
	at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.AbstractUpdateQuery.run(AbstractUpdateQuery.java:26)
	at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.AbstractDBAction.invoke(AbstractDBAction.java:66)
	at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:435)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:523)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
	at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
	at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1410)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:764)
	at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1665)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:527)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:131)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:598)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:223)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1580)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1384)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1553)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1306)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
	at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
	at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:301)
	at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:51)
	at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:141)
	at org.eclipse.jetty.server.Server.handle(Server.java:563)
	at org.eclipse.jetty.server.HttpChannel$RequestDispatchable.dispatch(HttpChannel.java:1598)
	at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:753)
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:501)
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:287)
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
	at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:558)
	at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:379)
	at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:146)
	at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
	at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:421)
	at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:390)
	at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:277)
	at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.run(AdaptiveExecutionStrategy.java:199)
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
	at java.lang.Thread.run(null)
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO mytable (tagid, value, timestamp) VALUES (?,?,?), [3, 1.5, {'$ts': 1759233600000L, '$': ['ts', 192, 1760644157017L]}], , , false, false)
This is not strange, this is the standard way to store a timestamp.
" The Unix epoch (or Unix time or POSIX time or Unix timestamp ) is the number of seconds that have elapsed since January 1, 1970 (midnight UTC/GMT), not counting leap seconds (in ISO 8601: 1970-01-01T00:00:00Z)."
system.date.fromMillis(1760647890223 * 1000) will get you back to a date object.
Sure, I am aware of Unix epoch…I guess my question is can the whole timestamp object (with its “$”: [“ts”,192, and the “$ts”: structure) be converted directly…or do I have to go in and fetch the “$ts” key’s value from that object.
It looks like you are converting a whole timestamp structure from a tag, not just the value itself, the 192 refers to tag quality:
You will not need to manually do anything with the tag quality value as it will be automatically applied if you write it to a tag.
The $ + $ts is Perspective's proprietary "dollar qualified" encoding scheme used to pack extra metadata in to values we send to the frontend, since JSON doesn't support 'rich' types like qualified values that bundle value + quality + timestamp.
The inner $ts is the epoch millis that the value contains. There's no static utility function to import that will reverse the qualification for you, because the logic to do that lives on the frontend in Typescript code, so you'll have to script your own workaround in Jython.
