How to create active directory user source in ignition
I want to create active directory user source in ignition, but after creating active directory user source, if i click on manage users in active directory source, it will shows user source is disabled, i want to fix this issue can you help me, here is the screenshot which i am getting error
Please anyone reply my question
According to the documentation, this feature was disabled and deprecated due to a potential security vulnerability:
Here is a more detailed explanation:
I just tested this with putting a random IP for the Primary Domain Controller Host(for the record I don't have a active directory), I was able to recreate that same 'user source is disabled' when i hit manage users so I'd verify your pointing your active directory users at the right IP address or hostname of your primary domain controller.
You have been told multiple times on other threads not to do this.
Don't bump questions without making a decent attempt to supply more information.
I think you have the wrong feature and update that is causing the issue here. I just ran into the same issue in 8.1.36 and the new user source enabled boolean is auto unselecting itself when I save the user source. Will post back if I figure out why this is happening on a brand new install, while I didn't have the same issue when upgrading an existing.
https://docs.inductiveautomation.com/display/DOC81/New+in+this+Version#NewinthisVersion-Newin8.1.27
User Sources
