Hi everyone,
I'm working on a project where I need to create animations or transitions for pipes within a Coordinate Container in Ignition. My goal is to visually represent the flow/pressure within the pipes, using a blinking effect, potentially simulating fluid or gas movement through different sections.
Has anyone implemented something similar? Is it possible to achieve this effect since we cannot add a style class to the pipes, or would I need to use another approach or component to create these animations? Any advice or examples would be greatly appreciated!
Would be really awesome if i could animate the fill value inside the pipe object.
Thanks in advance!
