How to create equipment state class inside the "Equipment States" using scripting in sepasoft.
Above image is of Equipment Manager OEE State Class
Following example from Sepasoft user manual.
https://docs.sepasoft.com/articles/#!user-manual/mes-equipment-state/a/MESEquipmentState-eqstateObjectCreation
stateCls = system.mes.loadMESObject('YourStateClass','EquipmentStateClass')
#insert the name of your State Class here
name = 'YourStateName'
code = 12 #this is the state code provided by your PLC
state = system.mes.createMESObject('EquipmentState')
stateCls.addChild(state)
state.setPropertyValue('Name', name)
state.setPropertyValue('EquipmentStateCode', code)
state.setPropertyValue('EquipmentStateType', 'Unplanned Downtime')
#valid values for EquipmentStateType: "Running", "Idle", "Blocked", "Starved", "Planned Downtime", "Unplanned Downtime", "Disabled"
state.setPropertyValue('EquipmentStateOverride', 'Optional')
state.setPropertyValue('EquipmentStateOverrideScope', 'Detected Equipment State')
stateObjList = system.mes.object.list.createList()
stateObjList.add(stateCls)
stateObjList.add(state)
system.mes.saveMESObjects(stateObjList)
Was this successful for you guys?
state.setPropertyValue('Name', name), is unable to set the name of the state because of which I can't even save it as an MES object.
Would appreciate any help as I have to add a lot of states and doing it using the UI is a pain.
Thanks.
Yes. I implemented the exact code to import multiple states from a csv file.
Can you share error description?
