How to create screens for mobile devices in ignition 8.1
This text will be hidden
Duplicate of How to make perspective project to run & view in both desktop dashboard and mobile application - #3 by Shashiraj_P_S with the addition of a screengrab.
Please don't post duplicates. Fix the original question instead.
Search for breakpoint container in help file and tutorial video.
Ok sir
While I agree with @Transistor, stop creating duplicate topics for the same thing otherwise you will more than likely lose access to the forum if you keep flouting the rules, I will regardless reply here as this topic has slightly more info than the other one...
The breakpoint container just swaps between views based on the viewport dimensions. So you would need to create views for both mobile and pc versions of your app to use with the breakpoint container. You've created the pc version, so you should also be able to create a mobile version
Flex or percentage based containers work too. the screenshot looks simple enough for that to be easy too. but a basic lookup should have given him those answers already xd
Agreed. There is some improvement here.
https://docs.inductiveautomation.com/display/DOC81/Perspective+-+Breakpoint+Container
or in Designer you can find a sample project from there you can get learning too.
You're right, a flex view would work best for this main view, the header might be good as a breakpoint though. I highly suspect the main view is a Coordinate view (trap for beginners coming from traditional scada platforms)
Is it my imagination or has this Timkin logo featured in poor posts by a number of different users? Has nobody in the company studied the Ignition training material?
Yes, and over a significant time span. I wonder if they are using this disaster as an employment screen.
From the very little context given, I believe the screen shot is actually a vision application (I'm not sure that makes it better).
This part tells you its Perspective. I always turn this off in my projects though
Hahaha, it's the only thing that makes sense...
I love how there's radio silence from the OP for this entire conversation, and it's the same in all of his other topics as well
Lol, I don't even know what to say
Responses have already been given.
Welcome back :slight_smile:
What have you tried so far?
Based on past performance, probably nothing. (Check his/her forum activity history.)
Btw, we've been waiting for your response for almost all of our collective ~19 posts....
