I get two of these errors whenever I open a particular window (in the designer or in a client):
ERROR com.inductiveautomation.factorypmi.application.components.BasicContainer - Component name ‘’ is invalid, it is either non-unique, reserved, or has an illegal character.
Some searching on the forums suggest looking for binding in component names. I have not found any of those (it would be unintentional if there is one!).
Another post suggested looking at the XML, but I certainly don’t know what to look for in that output
Apart from the error box appearing, there doesn’t seem to be anything not working…
Any pointers on how to find out which component is causing the error will be gratefully received!
Can you post the full stacktrace from the error window when you hit that? The message is indicating that a name on a component is empty, but doesn’t indicate which one. The full stacktrace might be able to at least narrow it down a bit.
