I have downloaded the Ignition-ModuleSDK, How to debug the program of Ignition-ModuleSDK? (to see the value of varible when the program is running),Thank you.
First off, enable Java remote debugging for Ignition. To do this, edit the “ignition.conf” file found in “{Install Dir}\data”, and un-comment the two following lines:
wrapper.java.additional.8=-Xdebug
wrapper.java.additional.9=-Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=8000
Restart the Ignition gateway.
Now, you can set up Remote Debugging in Eclipse. Just create a new Remote Debug launch profile, and select your module as the project.
Hope this helps,
