How to delete dock border
img_v3_02i5_9c9709e9-5cae-4fc7-a0f5-029d8155dfcg
When I use openDock scripts,It give me this view that with a border.
How can I take the dock border-color into transparent?
Please don't use global css with .ia_popup to make it border-radius the same ,other docks don't want to use this css.
I defined a css name, but not works.
Show us the CSS and show us how you applied it. Otherwise we are only guessing.
This is the solution.
If you don't want the CSS to be global, then the trick is to create an Empty Style Class. Then select that class in combination with .ia_popup to make the border-radius the same.
Then it will not effect any dock that doesn't have that class applied.
